Advanced Engineering Tech For the more hardcore LS1TECH residents
formula to calculate engine size?
Old Sep 16, 2007 | 12:51 AM
ls2 bait's Avatar
Default formula to calculate engine size?
anyone got a clue? so far my best guess is bore x stroke x 25.4? but then my numbers come out a tad high on smaller cube engines and a tad small on larger cube engines.
Old Sep 16, 2007 | 01:32 AM
ChicagoTransAm's Avatar
http://golenengineservice.com/calc/calcci.htm
Old Sep 17, 2007 | 03:09 AM
nesikachad's Avatar
BORE X BORE X STROKE X .7853982 X How many cylinders there are.
Example, SBC:
4 X 4 X 3.48 X 07853982 X 8 ='s CID
OR 4 (squared) X 3.48 X Bla, bla, bla, X 8 ='s. . .
349.84
AKA the good ol 350 Chevy.
Old Sep 17, 2007 | 07:48 AM
Old SStroker's Avatar
Example, SBC:
4 X 4 X 3.48 X .7853982 X 8 ='s CID
349.84
.7854 is accurate to within a VERY small fraction of a % and is easy to remember: it's the four numbers on the top left corner of a calculator keypad taken clockwise. My old brain has trouble remembering strings of numbers, but I can remember this crutch.
FWIW, .78539... is PI/4
Oh yeah, it's counter-clockwise from the bottom left on a cell phone calculator.
Old Sep 18, 2007 | 12:36 PM
Hugger Z's Avatar
Just to clarify the actual formula for everyone. It is the cylinder area times the stroke times the number of cylinders. Area of a circle is pi*r^2 or pi*d^2/4. The pi/4 is where that constant .7854 comes from.
Bore^2/4 * pi * #cylinders = Engine Volume (in whatever units you are using, just make sure to stick to inches or mm so your numbers come out right. Mixing units will mess it all up).
Old Sep 18, 2007 | 04:39 PM
Wish I'd said that.
You might want to multiply your "Engine Volume" by the stroke. Your units came out in square inches or cm, not cubic inches or cc.
