Advanced Engineering Tech For the more hardcore LS1TECH residents
How does engine/ECM determine octane?
Old Nov 8, 2007 | 01:52 PM
Gregory's Avatar
Default How does engine/ECM determine octane?
Does anyone know the correct answer to this?
How does the engine/Engine Control Module determine the octane of the fuel?
The General Motors computers have two different fuel tables: Low Octane and High Octane. These tables have different engine timing numbers.
I've heard two different answers.
1.) The engine "tastes" the fuel. Perhaps some kind of specific gravity measurement is taken and this result is used to determine the proper table to use.
2.) Knock sensors determine the table used. If no engine knock is sensed, then the high octane/timing table is used. If knock is detected, then the low octane/timing table is used.
E85 engines add another setting, but knowing how the engine determines what table to use is important to tuning. Moreover, if knock is the determining factor, at what knock level does the computer change tables?
Does anyone know for sure?
Thanks!
Old Nov 8, 2007 | 04:20 PM
oz304's Avatar
The knock sensors determine the signal to the ecu pre programmed retard thresholds.
Therefore limiting the amount of knock retard is the key to improved fuel efficiency regardless of fuel used,each in their merits in conjunction with spark plug heat range,fuel pressures,and density of that fuel.
Old Nov 8, 2007 | 04:56 PM
3.4camaro's Avatar
Computer goes into low octane mode anytime it's shoved into Speed Density mode, like a MAF failure or something.
oz stop saying ye, it's wierd.
Old Nov 10, 2007 | 09:58 AM
oz304's Avatar
3.4,incase ye dunno what it means,its original english language centuries before ye ever existed or anyone for that for that matter.
now ye know,live with it or read ye bible and learn from it.
Old Nov 10, 2007 | 10:30 AM
3.4camaro's Avatar
Thanks for staying on topic.
Old Nov 10, 2007 | 03:41 PM
Gregory's Avatar
Well, both my High and low octane tables are the same. So, no resister is necessary. However, I'm not sure the details of a speed density tune and what tables are tuned.
In any case, without anyone actually saying it, it sounds like the knock sensors determine the engine advance, and not the fuel itself.
Interestingly enough, I've been able to add three degrees advance to both tables on my E85 Avalanche without issue. I only get one degree of knock retard when the engine shifts from V8 to V4 mode. Gas mileage and pep seem to be reliably improved.
Thanks for the feedback!
Old Nov 10, 2007 | 08:01 PM
2MuchRiceMakesMeSick's Avatar
so far my basic understanding of tuning is exactly what your saying gregory.
It will run whatever is in the VE / spark advance tables until it gets a signal back, that exceeds the threshold determined by the pcm, from the knock sensors which in turn causes the pcm to pull timing. Essentially you are setting the octane when you dial in your VE tables. Its a fairly simple setup as far as fueling is concerned, determining the type of air can get a little more complicated but I am still learning
Old Nov 11, 2007 | 03:59 PM
oz304's Avatar
Keep up the good works.
Adding advance or reducing knock retard amount on any fuel,yields better results,as would optimising typical factory 12-14 degrees knock retards to 1 or so degrees on most factory calibrated ecus.
Its amazing what can be done with carefull tuning of the knock sensor retard amounts along with the cruise modes that are carefully leaned as well,even better results become apparent.There is one bloke who claims he uses less than a gallon + a half of fuel per 60 miles on a trip with his lsx tuned engine, with the normal ulp!
Old Nov 12, 2007 | 11:13 PM
Hector's Avatar
Originally Posted by oz304
... original english language centuries before ye ever existed or anyone for that matter.
Old Nov 13, 2007 | 09:06 AM
3.4camaro's Avatar
ya, no one knows what the **** he's talking about. its still a lil bit funny.
Old Nov 13, 2007 | 03:33 PM
B T's Avatar
B T
Ye better get ready to repent.
Old Nov 13, 2007 | 07:29 PM
Alvin's Avatar
Question for a cookie?
What freq. does GM decide is best to listen for knock?
Old Nov 13, 2007 | 08:02 PM
Gregory's Avatar
Beats me, but I'll bet the frequency of the LS1 is different from the LS2 as the sensors are located in different areas of the engine.
Any more hints?
Oh, I picked up a reliable 1/2 mile per gallon with the three degrees of advance on both regular and E85.
Old Nov 13, 2007 | 08:36 PM
B T's Avatar
B T
Another cookie quest!
I'll grab a number out of the air and say 1200 Khz
Old Nov 13, 2007 | 11:25 PM
Steve Bryant's Avatar
LS1 Tech Veteran
The Knock Sensor operation is explained here http://delphi.com/manufacturers/auto/sensors/et/flat/. I'll look up the frequency for the LS series in my maintenance manual. I doubt that the frequency is much different for any V8, although I'm sure that the ECM is optomized for the engine series. If knock retard is sensed, the PCM/ECM migrates away from the High Octane advance value toward the Low Octane Table Table value. It's proportional to the amount of KR. If both timing tables are set the same, the PCM can't do anything to reduce knock. In tuning, you want to set the low octane table to be equal to the high octane table to discover where the knock is occurring (by logging the data) and then once, you've gotten KR under control, I like to set the low octane table up for about 7 degrees lower than the high octane table for a daily driver.
Steve
Old Nov 14, 2007 | 01:32 AM
GMC_DUDE's Avatar
I've wondered about this too. I can understand how if the ECU detects ping via the knock sensors, it will pull timing by using a weighted average between the high and low octane tables. But how does it know to advance the timing when e.g. higher octane fuel is used?
Old Nov 14, 2007 | 03:19 PM
3.4camaro's Avatar
It doesn't know when higher octane is used.
When the PCM senses knock, it'll go back to the low octane table, proportional to the amount of knock. It's called the "Low octane table" because it's assumed nothing is wrong, other than you put low octane in the car, which would cause knock.
Get what I'm saying?
Old Nov 14, 2007 | 10:42 PM
B T's Avatar
B T
GM PN 1997562, 1997699, OR Standard Motor Products KS45, KS46, KS49, or KS117 have a design frequency of 5200 hertz, and they produce a signal between 4800 rpm and 5600 rpm.
5200 Hz sound close?
no pun intended.
Old Nov 15, 2007 | 12:37 AM
2002_Z28_Six_Speed's Avatar
Oh, ****. Don't even get me started on screwed up Angle-Nordic Languages.
Even the people that know what a thorn is can't pronounce it. Don't try.
http://en.wikipedia.org/wiki/%C3%9E
One major reason for this is that Y existed in the printer's type fonts that were imported from Germany or Italy, and Thorn did not.
Yes, I knew that before referencing it on the net.
Old Nov 15, 2007 | 02:12 AM
GMC_DUDE's Avatar
So what you're saying is that once the knock sensor / ECU detects knock and scales the spark timing down towards the low-octane table, it will NEVER move it back up for the life of the vehicle, correct?
Sorry but I don't believe it.
There must be some method whereby the ECU eventually moves the spark timing up the scale until the knock sensors again detect knock and the ECU backs off. I am wondering what that method is.
