Header to x-pipe distance?
GTObessor is right, this is'nt exactly the correct forum for the thread as stated. However, if you read the forum guidelines https://ls1tech.com/forums/advanced-engineering-tech/396223-what-forum-please-read-before-posting.html, I think the initial questions could be restated to comply with the intent of this forum. For instance:
How can I determine the optimum header length and primary/secondary/collector pipe diameters for a stock LS6 used as a daily driver/occasional weekend strip car?
How do I determine the optimum distance from the collectors for an X pipe?
How do I determine the minimum exhaust pipe diameter for dual exhausts to support 450 HP?
Give some thought as to how this forum is susposed to be used.
Steve
