Advanced Engineering Tech For the more hardcore LS1TECH residents
Dry sump system design
Old Dec 30, 2007 | 07:14 PM
Mike454SS's Avatar
Default Dry sump system design
I want to run an LS7 dry sump setup on my new engine that I'm building, I already have the pan and pump (and a custom made crank to run the pump with a 3.622 stroke...and now I'm wondering if the LS9 crank in the new ZR1 will be an OEM solution to what I had made lol)...I'm probably going to be building my own tank though...or maybe something aftermarket...LS7 tank probably won't fit in my car...I guess I could mod the car to fit it, but it's stupidly expensive and I think some aftermarket tanks are better.
Are there any specific things I need to know about the tanks location in the car? How high does it need to be? How high relative to the ports on the oil pan should the outlet from the tank be? What else do I need to be aware of with a dry sump system?
Old Dec 30, 2007 | 10:52 PM
mrdragster1970's Avatar
6 & 8 Second Club
Tank location is usually wherever it fits.
The pump suction will pull the oil out, doesn't matter where the ports are, as long as the tank input is above the fluid level.
If you look inside the tank, there is a tube that runs up on an angle so you don't suck up metal. So it's not a gravity feed. The pump will draw it out.
One tip, I bought 2 used tanks for my cars. Work great & 1/4 the cost for a non-moving part. I also made some changes, much easier & cheaper than changing a chassis. Hope I made some sense. Good luck.
Old Dec 31, 2007 | 10:32 AM
Mike454SS's Avatar
Which tanks did you use?
So with that metal tube, I don't need to worry about the tank being slightly too high and flooding the oil pan when the car is off?
Old Jan 1, 2008 | 04:52 PM
6 & 8 Second Club
I use a Patterson tank on 2 of my cars. I love them. Well built, strong.
Don't forget I have a Pro-Modified, my tank can't flow past the pump.
I can only tell you about my system. Good luck.
Old Jan 1, 2008 | 09:12 PM
Mike454SS's Avatar
Yeah, I need to take the LS7 pump apart and see how it works...I don't know if it can flow past.
Thanks for your help though, I do appreciate it.
Old Jan 4, 2008 | 10:01 PM
DONAIMIAN's Avatar
Its basically 2 LS1 pumps stacked on top of each other. If you know how and LS1 pump works, save yourself the trouble of taking it apart.
