Here's an interesting question...
I'm sure there is a conversion equation somewhere out there, I just can't seem to find it searching the threads.
The only things that determine compression ratio are the displacement, piston, headgasket, and the combustion chamber.
The amount of vacuum in a setup has no affect on static compression ratio, as static compression is taken assuming 100% VE.
Now the flow you are getting into the engine (assuming no filter losses) is the sqrt of the difference between the vac you have and the rated vac times the rated flow.
If you are getting .5hg and the TB is rated at 750 cfm at 1.5" hg then the engine is taking in ~432cfm. Now assuming it would take a full 750 CFM to obtain 100% VE in this case the VE would be lower than that and the compression ratio the engine "sees" would be lower as a result. This is how it was explained to me anyway and may not be 100% accurate but it makes sense.
