Advanced Engineering Tech For the more hardcore LS1TECH residents
Gas Flow_Pressure
Old Jun 15, 2008 | 01:03 PM
tee-boy's Avatar
Default Gas Flow_Pressure
Would a 3.5" y pipe with a 3.5" to 3" reducer on the end create the same back pressure as a 3 inch y pipe?
Old Jun 23, 2008 | 07:21 AM
tee-boy's Avatar
anyone else? what's the difference b/w a 3 inch pipe and a 3.5 inch pipe with a 3 inch nozzle on the end, in terms of backpressure?
Old Jun 23, 2008 | 08:29 AM
briannutter's Avatar
I did quite a bit of exhaust testing on my c4 Vette. I found that the point of restriction was simply that. once it was opened up...the rest of the system worked fine. in my case, I went from 3.5 psi of backpressure at wot 5500rpm to .8psi through Random cats and straight through dynomax mufflers. That's about as good as it gets for a full length exhaust. I'd highly recommend that people do this testing before spending money on exhaust systems. Turns out the factory system was fine at my hp level with the exception of the mufflers themselves.
