Advanced Engineering Tech For the more hardcore LS1TECH residents
cylinder bore vs piston size
Old Jul 23, 2008 | 01:46 PM
95FbFormula's Avatar
Default cylinder bore vs piston size
I have a 6.0 lq4 I recently purchased a set of stock replacement pistons for. The seller thought they were .010 over but wasn't sure so upon receiving them I took some measurements and they are 4" diameter same as the bore size so does that mean they are .010 over or .005 I tried to find Lq4 stock piston diameter but no luck any help would be appreciated thx.
Old Jul 23, 2008 | 02:12 PM
Sbertolone's Avatar
what did you measure with?
Old Jul 23, 2008 | 02:19 PM
Just a standard tape measure I will be taking the pistons in to work to use my mic for a closer measurement
Old Jul 24, 2008 | 10:13 AM
blackz93's Avatar
Yeah, I'd do that.
Old Jul 24, 2008 | 05:22 PM
schino's Avatar
Originally Posted by blackz93
Yeah, I'd do that.
x2
you will get different measurements depending where you measure on the piston also so be aware. I was told by JE that they measure 1" up from the bottom of the skirt across the skirt. add a few thousandths to that and that should be the bore size.
