Advanced Engineering Tech For the more hardcore LS1TECH residents
How can you "overcam" your car?
Old Sep 13, 2008 | 07:28 AM
66deuce's Avatar
Originally Posted by chpmnsws6
Room is the restriction. So far all they've been able to fit in these cars are 1 5/8's inch shorty headers, but they are working on larger headers hopefully. I will not be buying a conversion kit until someone makes good header for it.
ahh,i see..a flippin Miada?i bet that thing is a rocket ship as light as it is...how many cubes are you running?stock size valves?
Old Sep 13, 2008 | 11:36 AM
chpmnsws6's Avatar
built 347, ported 5.3 heads with 2.02/1.60 valves, LS6 or another LSx intake, and backed by a built GTO trans
They typically weigh in around 2350-2400
Old Sep 13, 2008 | 12:20 PM
66deuce's Avatar
wow,that is light..
depending on the lobes your cam guru says to use,and your power goals/target rpm range,i would be tempted to use something a little smaller..something like a 224/230,xer int,xe exhaust lobes for example..this is just a guess,i'm not a cam expert.
if your cam guru really know's what he's doing,then by all means listen to him..
i like smaller cams in general,especially if your exhaust restricted..
Old Sep 21, 2008 | 11:20 AM
GrannySShifting's Avatar
Its simple why you cant you a bunch of camshaft. Olds is talking abotu delta p, pressure differential your using to drawn in an intake charge.
If you have a restrictive exhaust, you have backPRESSURE. Theres a much smaller window to pull an intake charge in from an area of slight pressure (on top an intake valve) to a lower pressure in the exhaust because as rpm and backpressure come up there isnt a lower pressure, backpressure starts to tilt your seesaw back. Usually as rpm comes up you can get momentum of intake charge to start moving more and more air, but with somethign exh restricted youll also see more and more backpressure as rpm comes up leveling the playing field. Sure you you were helping things a bit with the piston pulling on the door a bit on the way down the bore, but the exh valve will be open with some cam overlap letting that backpressure make a mess of things
Exhaust restriction suck, or they prevent it actually, which sucks
Old Sep 21, 2008 | 01:40 PM
GTOSE's Avatar
Now you have my attention
And off I go to get my ME degree.
Old Nov 2, 2008 | 09:55 AM
AUSTRALS1A's Avatar
That was the answer I was looking for
Hang 5, didn't the original post say exhaust was the prob... not intake??
Granted the long runner ls intake keeps power capped to around 6300 as stated, but the exhaust as spec'd would simply detune that combo further unless an "over cammed" exhaust was used to recover some of the loss that those pipes create.
Old Nov 2, 2008 | 12:26 PM
chpmnsws6's Avatar
intakes not the problem. It will now have a FAST 90 on it.
Old Sep 29, 2011 | 10:35 PM
NoShow's Avatar
So chpmnsws6, according to your sig I should never buy or sell anything to this person?
