Injector Shut off?
My assumptions were the injectors shut off at closed throttle, relatively quickley when left in gear (manual) rolling up to a stop light, assuming the engine speeds were up, maybe aboue 1500 rpm or so.
A couple guys weren't aware that modern fuel injection had this feature. others claimed there was more criteria that had to be met before shutoff.
Test run on my dd (2000 cavalier), I only got em to shut off once, while engine braking down a steep hill, and seemed to take a while to shut off. Although I was watching the o2 sensors on the tech2 because I could not find the FI plusewidth data item.
Does anyone have any good information regarding this topic?
Thanks
I've used this feature on both my Olds and Camaro. The Camaro I tuned with the HP Tuner and enabled it to come on earlier and on more vacuum than stock, so when I'm off the throttle at highway speeds, it comes on and slows the vehicle down. It's great for when you're in traffic and the speed varies greatly, also for slowing down to an exit ramp.
But yes, the DFCO does have the information I was looking for. Thanks.
