Monster Tach install
Old Jan 16, 2002 | 04:19 PM
Marty's Avatar
Default Monster Tach install
Just got one, how do I install it?
Old Jan 16, 2002 | 04:24 PM
BIGBOS's Avatar
Default Re: Monster Tach install
I had a local shop do mine, if your looking for a place to install go to the pics in my profile... <img src="gr_stretch.gif" border="0">
Old Jan 16, 2002 | 05:32 PM
Sears's Avatar
!Dial-up Director
http://www.ls1.com/ls1forum/Forum21/HTML/001077.html
[quote]You can find an ignition wire and illumination wire behind the radio...the yellow wire (next to the ornage wire) is the ignition and the brown (same section as the yellow) is the illumination. Or you can tap any pink wire in the ignition harness for the ignition and the brown wire behind the headlight switch for the illumination.
Do a search for the tach wire...its either pin #35 or Pin #10 at the PCM. I believe its 35 for the 98s and 10 for 99 and up.
Kevin<hr></blockquote>
What year is your car? It is pin 35 for the 98s and pin 10 for the 99s and up. <img src="gr_stretch.gif" border="0"> You also need to clip the orange and brown wire loops behind the tach to put it in four cylinder mode. Check the instructions to make sure I've got the right colors. <img src="gr_images/icons/wink.gif" border="0">
Good luck,
Justin
[ January 16, 2002: Message edited by: Jsears8 ]</p>
Old Jan 16, 2002 | 06:03 PM
Marty's Avatar
its a 00
Old Jan 16, 2002 | 07:02 PM
Doug Tschantz's Avatar
Marty,
On your 2000 you are looking for a white wire in the number 10pin location on the PCM. This will be the one that is towards the front of the car of the 2 PCM boxes. Don't forget also that the tach uses a 4cyl. pickup! Good luck, it's fun turning on the shift light....
Doug
00 Pontiac
