PRO STAR sizes and back spacing?
Old Jan 21, 2002 | 07:01 PM
1 BAD BIRD's Avatar
Default PRO STAR sizes and back spacing?
I am looking for some pro stars <img src="gr_stretch.gif" border="0"> 15x3.5 and 15x10s What sorta back spacing should I get? And tires? what sorta tires?
bob
Old Jan 21, 2002 | 07:39 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: PRO STAR sizes and back spacing?
First of all, you need to be sure to get the 4.75" lugnut bolt circle size.
15x3.5 only comes in one backspace - 1.75"
15x10 you will need the 7.5" backspace
You will also need 4 ea 5/16" spacers, and long-shank lugnuts in 12mm x 1.5 size, with washers.
Front tires are 165r15 steel belted radials. I have some called "monarch metric" and they were $30 each from Discount Tire.
Rear tires will depend on if you want to run on the street, or track only, or both.
Nitto Drag Radials 275/50/15
ET Streets 26x11.5x15
ET Drags 26x10.5x15
Hoosier Slicks 26x10.5x15
Tony
Old Jan 21, 2002 | 07:50 PM
1 BAD BIRD's Avatar
tony I am sure there is grinding involved? Dyou know how much? or where I could take them to get ground down?
bob
Old Jan 21, 2002 | 07:57 PM
Nine Ball's Avatar
LS1Tech Co-Founder
No grinding needed on the fronts. The rears will need to be ground alot though. Any shop with a 4" disk grinder should be able to do this, you have to grind/test-fit/grind/test-fit/grind etc... until they fit without scraping on the caliper.
Tony
Old Jan 21, 2002 | 08:45 PM
1 BAD BIRD's Avatar
Tony? is it safe to grind the calipers? And is it also safe to run the 5/16" spacers all around?
bob
Old Jan 22, 2002 | 11:45 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have my rears ground down enuff to run no spacers in back.
I would reccomend following me if you leave the drag rims on the car 24-7 like me. I have oh 7K miles on my calipers.
Old Jan 22, 2002 | 11:47 AM
NASSty01's Avatar
And you want to get open-ended lugnuts too. otherwise you might have to take them off when you teched in at the track.
Not sure if you need them for the front also.
Long-shank lugnuts all around or just rear?
Would a 15x9 with say 7or7.25 BS require less grinding?
Rick
[ January 22, 2002: Message edited by: NASSty01 ]
[ January 24, 2002: Message edited by: NASSty01 ]</p>
Old Jan 22, 2002 | 01:45 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Why are you looking at a set of 15x10's? That's going to give you a LOT more tire than you'll need. Are you planning on some serious mods in the future?
__________________
Old Jan 22, 2002 | 01:49 PM
1 BAD BIRD's Avatar
ARE stage 2 h/c/i TH 400 a 4400 converter and 12bolt with 4.10 <img src="gr_grin.gif" border="0">
bob
Old Jan 22, 2002 | 08:15 PM
mmiller's Avatar
Texas Director
Tony,
What B.S. for 15" x 8" & 15" x 9" Draglites?
What is the best Draglite wheel size for 26" x 10.5 slicks, 26" x 11.5 ET Streets or 275 50 15 Nittos?
<img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Jan 23, 2002 | 09:57 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Bob, I had my Draglites on the car 24/7 and drove it for a full year that way (about 22K miles) and had no issues with brakes, spacers, or anything. The front brakes handle about 80% of the load, so grinding the back ones isn't as critical.
Rick, ALL of the draglites/prostars require the same amount of grinding. They grind on the backside of the face of the wheel, and all of these wheels have the same face. Yes, long shank lugs all the way around.
Matt, you need 5.5" backspace for the 15x8 wheels, and 6.5" backspace for the 15x9 wheels. All three of those tire choices would work the best with a 15x10 wheel, 7.5" backspace.
Tony
Old Jan 23, 2002 | 11:03 AM
mmiller's Avatar
Texas Director
Thanks Tony!
Old Jan 23, 2002 | 11:16 AM
LS1Tech Co-Founder
[quote]Originally posted by 1 BAD BIRD:
<strong>ARE stage 2 h/c/i, T400, a 4400 converter and 12 bolt with 4.10s - bob</strong><hr></blockquote>
Sounds like torque city.
I'd go 15x10's with something like a 11.5x26x15 ET Street or 27x11.5x15 Hoosier...
When you put a spacer on back, you don't have as much thread contact. IMO I would not run spacers with stock lugs out back on a car that cuts low 1.5 60 ft times. I have Xtra long wheelstuds but opted to grind down my calipers too. I'm hoping for high 1.4's...
Old Jan 24, 2002 | 01:04 AM
1 BAD BIRD - Yeah, I think you'll need the extra tire. <img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
__________________
