Blinkers not working
Old Sep 21, 2003 | 10:01 AM
*98Formula*'s Avatar
Default Blinkers not working
This is probably not the right place to post this but I can't get my right blinker to work again. I was driving home yesterday and went to turn it on and the light on the console just stays lit. My left blinker works great so it can't be the blinker switch. Bulb burned out maybe? If it is then it would have to be in the rear somewhere how do I get that assembly off on my 98 formula so I can change the rear bulbs.
Old Sep 21, 2003 | 10:27 AM
Danny2tek's Avatar
Default Re: Blinkers not working
turn on the blinker all working bulbs for that side will lit steady the one thats of is the burned out one if it's a rear one just remove the trim panel from within the trunk loosen the nuts and the taillights come off
Old Sep 22, 2003 | 01:54 AM
pimpmaro's Avatar
Sounds like someone needs to add some blinker fluid...
Old Sep 22, 2003 | 10:01 AM
Xsta Z 28's Avatar
One of your right side lights is burnt out. That is "how" the car tells you a bulb is burnt out.
Old Sep 23, 2003 | 03:55 AM
rspect's Avatar
I had the same problem with my blinker. It was a bulb problem in the front. Once I replaced it than I was back to normal.
