Need help with FRC installation
good luck!
-anthony
B) Yes, It makes it s bit easier if you remove some of the metallic tape around the fuel lines. I usually just take it bakc to the valve which only removes an inch or two. But that is enough to help. Some people remove it all.
3) If they are teh carbon fiber units with no 'c-clips' on the back of them, then there is no way to attach them. I believe they were originally made to fit over & secure to the OE GM covers. Although, you can adhere/epoxy/glue on some zip-tie clips & attache them that way. Yes, it has been done that way also.
