stain removal on carpets?
Old Dec 10, 2008 | 04:46 PM
kyles2000z's Avatar
Default stain removal on carpets?
a friend of mine called me today wanting to know if i could remove some stains he had ont he carpet in his tahoe. is there anything that works welll that is available from parts store that is worth a crap and removes stubborn stains well?
when i do it, im going to obviously scrub the carpet real hard with a stiff brush to loosen the dirt, and then use warm water mixed with whatever cleaner is recommended, and a shop vac to clean it. just wondering what would be best to use with this method that is readily available at advance, oreiley's, etc.
Old Dec 10, 2008 | 04:58 PM
blk/slvr02ss's Avatar
I use the Tuff Stuff Foaming spray and warm water and a scrub brush works well
Old Dec 10, 2008 | 05:12 PM
Friedrice's Avatar
I use this stuff in a light blue can. Its like blue magic or something. Took gum from the GF off my floor mat. Then I used a home steam cleaning machine.
Old Dec 11, 2008 | 08:58 AM
wannafbody's Avatar
Blue Magic or Spot Shot
Old Dec 11, 2008 | 09:01 AM
Camaro_94's Avatar
Yep. That stuff works good.
IF that doesnt get it out though, try shampooing the carpets.
Old Dec 11, 2008 | 10:13 AM
Brian2006's Avatar
Surprised no one has mentioned blue coral. I've had some good luck with that in my DD
Old Dec 11, 2008 | 12:43 PM
kyles2000z's Avatar
i saerched some detailing message boards, and they all spoke of a product called Folex. big white bottle with a triggger spray. you can get it at BiLo, Lowes Home Depot, etc.....anyways it worked reallly well!
Old Dec 11, 2008 | 12:58 PM
ZaneO's Avatar
Yes, I use Spot Shot, 303 Carpet, and Folex with pretty good success. It all depends on exactly what type of stain/soil you're dealing with.
Glad it worked out for you.
 Michael S. Palmer
Old Dec 11, 2008 | 01:06 PM
kyles2000z's Avatar
it removed dirt, blood, and some oil spots. but this carpet had transfer case fluid
(the stink stuff) spill out on it and these are being real stubborn. but i guess theres only so much you can so without a high dollar machine, correct? regardless, im impressed with the stuff!
