Fender to door gap.
BTW where are you located? if you are in So Cal i can offer to lend a helping hand to get it straight again.
used a leather hammer and a piece of nylon wedge. bent them till the fenders lined back up. once it warms up a bit ill get it on jackstands and remove the fenders and fabricate some new mounts
Aside from that, another thing is that the 4th gens are filled with uneven body gapping. You will get all kinds of gaps that won't match from side to side, either with the doors and fenders, the bumper seam where it meets the fender, and the trunklid, even the t-top edges. I've learned to live with them since it was something that was designed in. The lift procedures, however, you will need to be on top of everyone that lifts the car.
Edit
^^ The TA above. The tabs with the two bolts has to be bent back (carefully) until its pointed downwards and/or you have a good door/fender alignment. See the other posts above.
and fixed.
