Clay Bar!
Old Dec 25, 2008 | 09:57 PM
Hugger-96-lt1's Avatar
Default Clay Bar!
Hey guys need a little advice with the clay bar. I never used it but will be doing it soon. I found out were i work the detail shop has them and i would like to know how you guys use them and just details about it. I would ask them but i never seen them use it. lol
Thanks
Old Dec 25, 2008 | 10:14 PM
bobbyd's Avatar
make sure you use some lubricant when using clay bar. you can either use the spray that comes with it when you buy it or you can use a sprayer with dish soap and water.
also the directions are as follow.
1. wash car
2. dry car car
3. clay bar car.
4. rewash car
5. dry
6. wax car
7. detail spray on car.
search for clay bar and you should get more info on it
Old Dec 25, 2008 | 10:21 PM
Thanks, Once i clay bar car and wash it how will it look without wax and the detail spray.
Old Dec 25, 2008 | 10:29 PM
1BAD_LS1's Avatar
Restricted User
Clay bar worked wonders on my car really made it SHINE!!! I used one for the first time this summer.....its really worth the time....good luck man!
Old Dec 25, 2008 | 10:35 PM
I will be doing it on a black car, and i can see on your sig the car is black right. Do you have to do any polishing with a buffer or anything?
Old Dec 25, 2008 | 10:53 PM
Greenbird97's Avatar
The clay bar will remove any surface contaminants, dirt, etc. that is on/in the clear coat. It will also remove all prior waxes/polishes so you will want to polish, then wax after you clay bar it. You can just wax it after you clay bar it, but it will look a lot nicer if you polish then wax!
Old Dec 25, 2008 | 11:04 PM
Greekey's Avatar
Clay baring is out of this world amazing!!...Do it. No hesitation what so ever.
Old Dec 25, 2008 | 11:10 PM
Lol Thanks guys and i have heard lots about it but never seen it done in person. I work for a paint and body shop and we have never used it. So im anxious to see the results in person. ( Trying to stay away from the buffer)
Old Dec 25, 2008 | 11:16 PM
Greekey's Avatar
If you dont have expierence with a buffer, stay away. Another thing I can recommend for you is Meguiar's tech wax 2.0. I used this after claying my car and it left me speechless. Heres the link to the clay bar kit I used
http://www.prolongsales.com/index.ph...4&currency=USD
Tech Wax:http://www.amazon.com/Meguiars-Gener.../dp/B0002UQATS
Old Dec 25, 2008 | 11:25 PM
Thanks for the info. And i do have experience with the buffer thats why im trying to stay away from it. I hate it !!!! lol I buff enough at work and its the last thing i wan do at home. Thats how the clay bar got in my head. Ill keep u guys tips in mid.
Thanks
Old Dec 25, 2008 | 11:40 PM
95 bright teal's Avatar
Claying is always a good idea if it has not been done, just make sure it is well lubricated, if your not sure, put more lubrication on. as your doing it you will feel less and less resistance. fold the bar often so your not dragging contaminants around.
I would at least do a fine polish, but it can be followed directly with wax.
And you have to wax it, because clay removes most of the wax on the car
Old Dec 25, 2008 | 11:56 PM
Thanks for the advice. I am actually going to do it on a truck exactly like yours lol.
Old Dec 25, 2008 | 11:59 PM
So are you trying to correct something or just get smoother paint?
Old Dec 26, 2008 | 12:04 AM
1BAD_LS1's Avatar
Restricted User
I used the Meguiars clay bar kit...worked great! Just take your time put a good coat of wax on and your set! It took me like 8 hours to clay and wax my car but well worth it! Black kicks *** but you gotta wash your car every other day...lol
Old Dec 26, 2008 | 02:19 AM
TA adam's Avatar
so what is some good polish to use ? ice polish maybe? because i have tech 2.0 wax, ice detailer spray(amazing) and ice car wash and ive been thinking about claying my car also id prolly buy the meguires clay bar kit but im just unsure about the polish and exactely what it does. thanks
-adam
Old Dec 26, 2008 | 02:45 AM
hlaalu's Avatar
-adam
i like the meguires 3 stage system, that has the cleaner, polish, and then the wax. i find the best results with the polish is when you use a buffer. doing by hand just doesn't work as well.
i also have the meguires clay kit, i think its great.
Old Dec 26, 2008 | 02:48 AM
1BAD_LS1's Avatar
Restricted User
Meguiars Deep Crystal Polish...
Here is basically a video collection with how to's on all the Meguiar products!!!
http://www.meguiars.com/video/index.cfm
O ya polish is to remove swirl marks and small defects!
Just watch all the vids you learn alot...
Old Dec 26, 2008 | 09:43 AM
SparkyJJO's Avatar
If I can use a clay bar, anybody can do it
Old Dec 26, 2008 | 09:57 AM
QWIK Z of OP's Avatar
1. wash car
2. dry car car
3. clay bar car.
4. rewash car
5. dry
6. wax car
you can cut out steps 2-4, if as you are washing a panel while the soap and water are still on the car then clay bar right then. that is the quickest way to clay bar and wash your car, but do it in panels b/c you dont want the soap and water to dry or run off the car.
Old Dec 26, 2008 | 12:37 PM
3ls1s's Avatar
thats a good idea.i never understood the washing again after claying.i know zaino says to do it that way,but i think it is a complete waste of time.and yes it is well worth it makes a difference in looks and the wax/sealant will last/protect longer.
