Installing White Face Guages
Old Mar 8, 2002 | 11:44 AM
FreakZ's Avatar
Default Installing White Face Guages
Anyone have an article on installing White Face Guages? Install University doesn't.
Old Mar 8, 2002 | 01:52 PM
AlonzoVersion 1.0's Avatar
Default Re: Installing White Face Guages
[quote]Originally posted by Silver99LS1:
<strong>Anyone have an article on installing White Face Guages? Install University doesn't.</strong><hr></blockquote>Its very easy just make sur when you put them on all the needles are facing up.It makes it easier if there are 2 people doing it.You will also need a screw driver to kind of move the needle upward.Its only a few screws holding the cluster in after you take out the screws you have to tug on cluster because it is connected to a harness but be careful though.Its very straight foward.I did the nr ones with the electrical switch so I can change mine to blue or green with the flip of a switch.I grounded it out with the bolt by the drivers side left leg underneath the side railing or whatever its called but it has to come off to get to the bolt.Then I took my light switch out and spliced it in with the skinny gray wire that is connected to the light panel switch.I hope this helps.
Old Mar 8, 2002 | 02:20 PM
PewterZ's Avatar
[quote]Originally posted by The Booker Man:
<strong>Its very easy just make sur when you put them on all the needles are facing up.It makes it easier if there are 2 people doing it.You will also need a screw driver to kind of move the needle upward.Its only a few screws holding the cluster in after you take out the screws you have to tug on cluster because it is connected to a harness but be careful though.Its very straight foward.I did the nr ones with the electrical switch so I can change mine to blue or green with the flip of a switch.I grounded it out with the bolt by the drivers side left leg underneath the side railing or whatever its called but it has to come off to get to the bolt.Then I took my light switch out and spliced it in with the skinny gray wire that is connected to the light panel switch.I hope this helps.</strong><hr></blockquote>
Where is Texas do you live? I live in Plano. Just north of Dallas....You want to do another set? What price is fair?
Old Mar 15, 2002 | 01:33 AM
PewterZ's Avatar
ttt
