turn signal keeps burning out
My passenger side front turn signal light went out last week so I replaced it over the weekend. Now less than 5 days later the new bulb I just put in Saturday went out too <img src="gr_sad.gif" border="0"> <img src="gr_images/icons/mad.gif" border="0">
Could this just be an unlucky coincidence, or should I look into potential other electrical problems that may be causing this?
Any suggestions would be appreciated <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Thanks <img src="gr_images/icons/wink.gif" border="0">
-Bradster <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
<strong>Any Formula owners out there ever have problems with their turn signals burning out?
My passenger side front turn signal light went out last week so I replaced it over the weekend. Now less than 5 days later the new bulb I just put in Saturday went out too <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Any suggestions would be appreciated <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Thanks <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Bradster <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would just replace it and if it happens again then I would call the dealership.
-B
Josh S.
P.S. put some electrical grease on the end of the buld.... it should help some corrosion if that problem occurs with you
Thanks for the input, I'm going to change the bulb AGAIN this weekend - and keep my finger's crossed <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
<small>[ March 13, 2002, 04:23 PM: Message edited by: Raven99 ]</small>
Did you get an 'exact match' on the part number or a cross referenced bulb?
I was able to find an exact part match..no problems.
Grease or no grease..
(TURN SIGNAL BOOGERS!!)
I just replaced it directly..no troubles...
Oh BTW, this same problem shorted out my horns too.
Funny thing is, the driving light element in the light still works. Just the higher intensity element used for the turn signal has blown out each time. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
-Bradster
I got under the car this morning and took the problem bulb out and found that it was NOT blown out (?).
So then I checked the socket it went into and cleaned off the terminals as best as I could with a Q-tip. Then I cleaned up the bulb and it's terminals (used gloves and a clean rag), put some fresh dielectric grease on the bulb and put it back in - VIOLA! It worked! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I guess the problem was a combination of a bad connection plus some sloppiness on my part the first time around. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
At least all seems well now - live and learn <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks again for the support <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
-Brad
P.S.: as long as I had my car up on jack stands (again) - I went ahead and replaced the orange turn signal / driving lights with some Hyper-White blue bulb lights from APC <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> no more orange daytime running lamps for me!
<small>[ March 16, 2002, 01:32 PM: Message edited by: Raven99 ]</small>
