Computer Graphics Question.. Trans Am
Old Jan 25, 2009 | 08:48 AM
phantomzer0's Avatar
Originally Posted by TORCHD 02 TA
What is vector
You can make vectors with PS and the pen tool! Didn't I say that..... ???
Old Jan 25, 2009 | 08:43 PM
TORCHD 02 TA's Avatar
Originally Posted by evilZO6
I Have them all i own a graphics shop. Vector is a file which uses point to point plotted orientations to draw a computer rendering. Its how my machine knows how to cut. When you print something normally, it goes back and forth and does it line after line after line. Vector file tell the machine "put your needle(or pin tip) down here, Then move it to the right this amount and back this amount and the same time etc etc to make a curve. So instead of going line by line, its a mechanical hand that literally draws or cuts the image. Architects use the same machine as me. You can interchange the end of the mechanical arm. I have blades to cut vinyl, fiberglass, or carbon fiber. I can change it out to match the'yre machine by putting little pens in it so instead of cutting, it will simply draw on large paper. Pm me exactly what you want. Or you know what? I'll post up all my gm stuff to help everyone out. I have 10's of thousands of logos and they're all copyrighted i own rights to them and im not making money off it anyway by posting it for you. Hope it helps you out. It may be a day or two before i can get to the shop!
Also, if theres a certain picture or something along those lines you want cut into vinyl, if you email it to me i can scan it and convert it into Vector format so you can have a sticker made. This wont work for stitches i dont think but they can scan it into theyre format the same way i can.
Thanks for explaining the Vector to me BTW if you are able to send it to me can you put it in .dxf or .dwg format. Here is my email: torchd@comcast.net
I was wondering do you have the file of the image below? And do you have the file for the TRANS AM lettering?
Old Jan 25, 2009 | 08:44 PM
Originally Posted by jetlag
+1
I used to work at a sign shop and we used to scan images and vectorize them all the time. It'd be a shock if Alan couldn't do the same?? But maybe I'm wrong.
He can do the same, but Alan is having a hard time getting the ''bird'' and ''TRANS AM"
Old Jan 26, 2009 | 05:57 AM
evilZO6's Avatar
yea i have them ill have to pick them up in the next few days
Old Jan 26, 2009 | 09:32 AM
what do you mean by that? You have to get the file?
Old Jan 26, 2009 | 12:17 PM
Bones87's Avatar
Torchd, try this site. I use it to find fonts when I'm doing photoshop work.
www.dafont.com
Old Jan 26, 2009 | 12:52 PM
www.dafont.com
i looked there, the only font close enough for TRANS AM is sofachrome. But that is not exact..
Old Jan 27, 2009 | 10:27 AM
Hoping the EvilZ06 will see this so i can got those files
Old May 21, 2009 | 10:54 AM
sorry to bring up my old thread. But i was still never able to get the "BIRD" and "TRANS AM" logos. anyone have them?
