Busy weekend cleanin
Old Jan 26, 2009 | 09:16 AM
7plagues's Avatar
looks amazing... im envious.
Old Jan 26, 2009 | 09:28 AM
97ramsst's Avatar
It looks incredible...I am really jealous of how clean it is. The idiot first owner of my car had it undercoated at the dealer and ruined the underside of the car. I think I could get it off and cleaned up but I am going to wait until I get a lift.
Is that a Corsa exhaust? Did you polish it or have it chromed...its hard to tell in the pics...if its just polished it looks INCREDIBLE! I have to do that to mine!
Old Jan 26, 2009 | 10:27 AM
D_Rock's Avatar
looks sick for sure man. Beautiful.
Old Jan 26, 2009 | 11:24 AM
TazmanSS's Avatar
Bummer on the undercoat, and I hear ya on the lift, I would love to have one of those, as you can see, I jack er up and sit er on jackstands...
I do have Corsa exhaust, I have buffed the stainless out to get er to shine, lots of hours on it for sure to get er to shine like that.
Thanks for your kind comments too!
Old Jan 26, 2009 | 11:43 AM
PERFECT Z28's Avatar
Looks good
Old Jan 26, 2009 | 12:20 PM
colby72olds's Avatar
Wow, looks amazing!
Old Jan 26, 2009 | 12:38 PM
NIGHTMAREWS.6's Avatar
Nice job there on the polishing, now comes the fun part, you'll fine yourself crawling up under there, and taking off the wheels quite often to wipe everything down. Its pretty easy to maintain, just stay away from driving when its wet out.
Try buffing the your rotors too with some white rouge, they come out really nice for shows.
Old Jan 26, 2009 | 12:41 PM
gotspeed13's Avatar
Looks great. What kind of polish do you use?
Old Jan 26, 2009 | 01:07 PM
Get the metal or aluminum part as smooth as possible with sanding, then use a tripoli compound followed up with some white rouge compound, you'll need a buffing wheel that at least spins at 3600rmp to heat up the compound, the results are a mirror like finish.
Old Jan 26, 2009 | 01:34 PM
_JB_'s Avatar
Looks better than new lol Good job!
Old Jan 26, 2009 | 02:10 PM
TazmanSS's Avatar
Master Formula
Old Jan 26, 2009 | 02:12 PM
  #32
TazmanSS's Avatar
Thanks for the tip on the brakes, I need to upgrade mine from the stocks for sure.....and by the way YOURS is SSSUUHHWWWeeeet!!
Old Jan 26, 2009 | 02:14 PM
  #33
TazmanSS's Avatar
What grit sanding do use? and where do you buy your compounds?
Old Jan 26, 2009 | 02:40 PM
  #34
Kikaofazz's Avatar
Thumbs up
It takes time to appreciate the extent to which you guys have gone to ensure that your undercarriages are pristine. I don't think the most scrutinizing judge could take points off either ride!
Both vehicles have undercarriages that are cleaner than mine was new! Way to go guys, I hope to one day clean up mine half as well as you both have yours
Old Jan 26, 2009 | 02:44 PM
  #35
baylove's Avatar
damn good job
Old Jan 26, 2009 | 02:56 PM
  #36
Depends on the how the piece is your polishing, if there's alot of pitting, i would use something in the 300 range, and up from there, to get it really smooth you will need to use a fine grit in the 1500-2000, once its totally smooth, then start buffing. The rotation of the buffing wheel at 3600rmp or more will heat up the compound, and thats where the magic happens. I'll see if i can dig up some before and after shots, i sanded off every piece of rust i could find under my car, especially the axles, and used por15 in a black gloss, and no more rust since then. replaced all my suspension, polished everything else. Not hard to do, just time consuming.
Old Jan 26, 2009 | 02:57 PM
  #37
Oh, i usually buy my compounds from eastwood, they have a nice selection, and my buffing wheels from there as well.
Old Jan 26, 2009 | 03:05 PM
  #38
SRfastZ's Avatar
damn that is very nice
Old Jan 26, 2009 | 03:09 PM
  #39
Get a wire brush for the wheel wells, start scrubbing all that gunk and rust out of there, then paint.
Old Jan 26, 2009 | 03:26 PM
  #40
TXws6's Avatar
props to you man, that sucker is clean!!
