T/A drivers power seat removal?
Old Mar 16, 2002 | 01:50 PM
Sears's Avatar
!Dial-up Director
Default T/A drivers power seat removal?
How do you remove the drivers side seat on a trans am?
Thanks,
Justin
Old Mar 16, 2002 | 03:41 PM
FastOrange99Z's Avatar
Default Re: T/A drivers power seat removal?
Well, on a Camaro there are 4 philips screws that are holding plastic covers over the nut that hold the seat in place. Move the seat all the way foward to get to the rear and all the way back to get to the front. Remove the plastic covers, the 4 bolts that hold it to the floor and the wire pigtail and your done.
<small>[ March 16, 2002, 03:42 PM: Message edited by: FastOrange99Z ]</small>
Old Mar 16, 2002 | 05:01 PM
CRAGER's Avatar
Administrator
I think the 4 bolts are 13mm or 1/2". You might need to use a wrench if you don't want to take the plastic covers off.
Then tilt the seat back and pop the quick disconnects. There are two, one for power and the other one is the air tubes for lumbar if you have it.
Very easy.
Peace,
Craig.
Old Mar 16, 2002 | 05:41 PM
Sears's Avatar
!Dial-up Director
Thanks, I figured those plastic covers needed to come off.
