moisture in clear corner lens
Old Oct 8, 2003 | 11:16 PM
slowz's Avatar
Default moisture in clear corner lens
this is the second set of clear lenses i have had. the first set lasted 6 mos before getting moisture and blowin the bulbs. this set lasted exactly 6 days. anyone else have this problem or know what im doing wrong. they seem to be sealed up pretty good. should i put silicone around the bulb socket?
Old Oct 8, 2003 | 11:24 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: moisture in clear corner lens
https://ls1tech.com/threads/showflat...;Number=763849
Old Oct 10, 2003 | 12:39 AM
joedrum71's Avatar
I drilled two small holes on the bottom's of each lense. Seems to work.
