The wiring for the Monsoon system is complete crap. They use way too many wires to do the job and they are all tiny. It is real easy to rewire these cars. I would recommend pulling as much of the Monsoon crap out of your car and then doing the system yourslef. If you want something symple than you can use an aftermarket cd player (or whatever) with at least 45 watts per channel and run speaker wires from the deck to the doors and the rear speakers. What I would do, especially if you want good clean sound and dont mind the extra cash and work.....is to get a good 4 or 5 channel amp and another 1-2 channel amp for the sub(s) (if you dont get a 5 channel to run the whole thing) find a place to stick them and run 3-sets (front, rear, non-fading) of RCA's (Pheonix gold, Monster, Lightning, etc....they can make a real big diff in the sound) and then run the speakers back from whereever you put the amps to the doors and rears or whereever you put the speakers. You will get your best sound by far using an external amp for all speakers and allowing the deck to do the signal stuff. As for speaker locations...my '95 (I miss her <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> ) I had a set of 3-ways up front...6.5" in the door, 4" and tweeter in custom kick panels....it sounded awesome. Everything is what your imagination, $$$, time, and constraints can come up with. You can check out the trunk of my old cam here:
http://www.ignitionsyndicate.com/shannon/
And if you some pics of the kick panels I can email you some if you want. <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
