Koni adjuster carpet questions
Old Feb 18, 2009 | 12:47 AM
some_punk's Avatar
Default Koni adjuster carpet questions
Since I just installed konis and stranos, I dont want to have to remove so much stuff just to adjust the rears. Does anyone have a pic of the rear carpet cut out so that they can adjust it without having to remove the interior.
Old Feb 18, 2009 | 12:54 AM
Black02SLPSS's Avatar
Your car should have the cutouts already there, just lay down the rear seat and they should be there. They were on mine, i found them after i took alot of **** apart to install them
Old Feb 18, 2009 | 01:44 AM
nemss1's Avatar
like stated, yes the cutouts should already be cut in the factory carpet
Old Feb 18, 2009 | 02:07 AM
MadIceV8's Avatar
Customizing Director
Yep the cutouts will already be there. You could have installed them that way too without pulling back any carpet . Pull the back seats and feel for them. It'll be in the upper corners.
Old Feb 18, 2009 | 07:33 AM
EchoMirage's Avatar
theyre already perforated. just use a razor knife. if you clean up the edges and cut off any excess jute padding that sticks out, youll never know its been cut.
Old Feb 24, 2009 | 06:05 PM
some_punk's Avatar
Cant seem to see any of these cutouts. Does any one have any pics of it?
Old Feb 24, 2009 | 06:24 PM
EchoMirage's Avatar
unless the carpet has been replaced, i cant imagine why you cant find it. if you put the carpet back into its original place after installing the shocks, just feel around the area where you had to tighten down the nut on the top of the shock. its in that exact area, about a 3x4in section of carpet. just feel around the carpet, and you should feel the perforations. the only reason i can think of is either the rug is skewed off position, or sometime before you bought it the rug was replaced with an aftermarket.
