**HELP** TA seat conversion /SS
Old Mar 30, 2002 | 07:55 AM
GM01SS's Avatar
Default **HELP** TA seat conversion /SS
If anybody that has done the install of TA seats in a Camaro. As you know the power for the Camaro uses a 2 wire connection and the one for the TA uses a 6 wire connection.......so the Q is, how did you do it?.............any help greatly appreciated <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 30, 2002 | 09:03 AM
Xsta Z 28's Avatar
Default Re: **HELP** TA seat conversion /SS
I have TA seats in my SS.
I would say you are missing the extra power harness from the TA. Now I'm assume you have the full power TA seats with the adjustable lumbar and side bolster for BOTH seats. The drivers is the only one with power "moving" features. There is a two wire power outlet under the drivers seat.
Then there is a six wire and two tube harness that will connect to that factory two wire floor plug, run under the center console, and connect to both seats. This harness is needed to connect the drivers seat to the passenger seat. It contains wires and air tubes for the air pump, under the pass seat, which controls both seats lumbar and side bolsters. Once you get this harness all will make sence.
Unfortunately you need to get this harness from the car that your seats came out of. I have contacted Pontiac, and have no listing for this part. I was in the same boat as you when I got my TA seats, but luckily was able to salvage the harness, which runs under the center console, from the donor car.
Andy
Old Mar 30, 2002 | 01:51 PM
GM01SS's Avatar
Andy.........Thanks for the heads up on the "proper" harness.........upon further inspection, i found it and of couse everything works fine, again thank you!!!!!!!!! Gary <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ March 30, 2002, 01:52 PM: Message edited by: GM01SS ]</small>
Old Mar 30, 2002 | 10:33 PM
Xsta Z 28's Avatar
Cool! Glad the info helped.
Andy <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
