Cleaning engine with simple green & water hose
the coil packs and rest of the engine are very water resistant..
Seriously.. if your that worried dilute it down some.. this is starting to sound like urban legends material
http://corvetteactioncenter.com/kb/q....php?qstId=261
1998-2002: Service Bulletin: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set
Subject: Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor)
Source: Chevrolet Dealer Technical Service Bulletin
Number: 02-06-04-023
Models: 1998-2002 Chevrolet Camaro, Corvette, 1998-2002 Pontiac Firebird
with 5.7L Engine (VIN G -- RPO LS1)
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Avalanche, Silverado, Sierra, Tahoe, Suburban, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL) with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59, LQ9, LQ4)
Condition:
Some customers may comment on a mild to severe engine ping (commonly referred to as spark knock), usually worse during acceleration and/or an illuminated MIL. Upon investigation, the technician may find DTC P0332 set.
Cause:
This condition may be the result of corrosion of the rear bank knock sensor due to water intrusion into the sensor cavity. This condition is more apparent on vehicles in which customers frequently wash the engine compartment.
Aluminum - Is it safe to use Simple Green on aluminum?
Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
I never use Simple Green full strength, and never spray it on until AFTER presoaking.
Engine cleaning one needs to be careful, <font color="blue">minivette<!--color--></font> , has very good points, and advising from personal experience, take it as you wish . . .
-- i wasnt bashing you but in the many years ive been here this is the first ive heard of this.. Maybe if you use simple green it should be diluted and then COMPLETLEY washed off? Maybe only use on the bottom section of the engine??I agree that simple green and polished wheels seems like a bad idea.. I personally only used simple green on the block (hard to reach areas).. i used car shampoo on the rest of the motor and wheels..
Thanks for the TSB
Also, I try to get this information on what happened to me out whenever I see one of these posts pop up. I may miss one here or there but I try.
Here and look at this chart to help you understand corrosiveness/acidity.
Chart
Many people have used Simple Green on things a lot more sensitive than aluminum with no problems. Did you ever consider that green stuff you found was copper from the water? Copper greatly affects pH. Your problem may have stemmed from cleaning your engine but it could not have been a result of simple green.
Chart
Look at the link I posted above to help YOU understand Simple Green's stance on their products. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process.
I personally haven't had probs with SG but im pretty carefull with its use. Other people have seemed to have problems. If your concerned just use soap and water. The TSB makes it sound more like a water issue than a solvent issue though.
On the nex FOX.. "when Simple Green attacks!!"
Correction
Replace the rear bank knock sensor and build a dam (wall) around the sensor using RTV to divert water away from the sensor.
Remove the intake manifold.
Remove the wiring harness assembly from the knock sensor.
Remove the rear bank knock sensor.
Install the new rear bank knock sensor. Tighten
Tighten the knock sensor to 20 N·m(15 lb ft).
Install the wiring harness assembly to the knock sensor.
Apply a bead of RTV silicone sealant approximately 9 mm (3/8 in) wide and 6 mm (1/4 in) high along the outside edge of the ridge on the engine block valley cover around the rear bank knock sensor. DO NOT form a complete circle. Leave the rear section open.
From the underside of the intake manifold, completely remove the rear intake manifold seal (foam material).
I've never had the intake off. What do they mean Foam Material on the underside of the intake manifold?
I was cleaning the engine cay and got sidetracked came back about 15minutes later and the valve covers looked real bad. Kind of like a "concrete camoflage" look.
