Weld Draglite & spacer ?
Old Apr 10, 2002 | 10:58 AM
FormulaWS6's Avatar
Default Weld Draglite & spacer ?
I am thinking about getting some Weld Draglites with the 5/16 spacer. This is for the 15x3.5 skinnies up in front. Will there need to be any grinding involved with the spacer? Or will the spacer just do it?
Also, some day i will get some 15 in. Welds for the rear. What sizes do you run? I will run a ET STreet or Hooiser QTP. Run low 12 N/A and will be installing nitrous soon. Thanks..
Old Apr 11, 2002 | 12:41 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Weld Draglite & spacer ?
With a 5/16 spacer up front the skinnies fit fine and require no grinding, that is my setup...
www.ls1tech.com/moderators/psj
