Engine detailing
Old Mar 9, 2009 | 10:35 PM
CubanGT's Avatar
Default Engine detailing
Need to find a good place to have the engine detailed in the houston / katy area..
i plan on degreasing the bottom parts of the car to try to find a leak, but the rest of the engine needs to be cleaned also we can start taking care of any issues that surface after having a clean motor to work with..
looking for suggestions on a location that does a good job..
thanks.
Old Mar 20, 2009 | 11:21 PM
CubanGT's Avatar
bump it up
Old Mar 20, 2009 | 11:25 PM
TORCHD 02 TA's Avatar
you can do it yourself.. Are you afraid to spray water on your motor?
Old Mar 21, 2009 | 12:22 AM
DevilDougWS6's Avatar
they make foam stuff that you spray on and rinse off. or if you are ballsy enough cover up delicate electronics and steam pressure wash it.
Old Mar 21, 2009 | 10:42 AM
WS6Power's Avatar
Don`t get the knock sensors wet! They are a pain in the *** to replace!
Old Mar 21, 2009 | 07:10 PM
hotZ28cammed's Avatar
i just use simple green on a towel and something to sort of scratch it with
Old Mar 21, 2009 | 09:44 PM
CubanGT's Avatar
thanks for the replies..
so if i use the foam.. are there any parts i should be careful with? is it that easy to just spray and rinse with hose?
