halo question
Old Mar 9, 2009 | 10:40 PM
z28camaross2's Avatar
Default halo question
hey everyone just wondering how the halos hook up. if you turn on your parking lights do they come on or can you make it so that there is a seperate switch? so if i only want my parking lights on and fogs i might not want the halos on sometimes. just deciding if i wanna pic up a pair of projectors with the halo on em or not.
Old Mar 9, 2009 | 10:41 PM
SparkyJJO's Avatar
All the projectors come with halos. Whether you hook them up or not and how you hook them up is up to you. I put mine on a switch, although I usually just leave them on.
Old Mar 10, 2009 | 03:59 PM
was it easy to install the switch for it?
Old Mar 10, 2009 | 08:49 PM
SparkyJJO's Avatar
I ran the ground connections to one of the grounds inside the engine compartment, then ran a wire up the edge of the fender through the doorjam into the inside to a switch hiding in my ashtray. I put a wire with an inline fuse in the "ign" spot in the fuse panel. Not the prettiest setup so I may change it but it works for now.
Old Mar 10, 2009 | 10:29 PM
Z28LS1camaroguy's Avatar
ground it, best place to get power is the accessorie terminal under the hood, and then run the wire up to your switch which is also grounded. I put an inline fuse in mine just incase something were to happen.
Old Mar 10, 2009 | 10:46 PM
thanks guys, anymore input from anyone would be greatly appriciated.
