Whiteface Gauges
peel off the old face, put on the new one, use some rubber cement if there is no glue left from the original face. replace needles, install and go.
Just make sure you're using soapy water in a spray bottle to "lube" the stickers so you can move them around.... then install the cluster and turn on the lights to see that the overlays are not covering the numbers.
If it's good, then just squeegy the overlays down and re-install.
It's that easy, goodluck!
Hope this helped.
at home i've still got the instructions, and i can scan them for ya.... tonight.
