Cutting the gear shift rod '02 Formula
Old Apr 19, 2009 | 05:40 PM
Wisp's Avatar
Default Cutting the gear shift rod '02 Formula
I really dislike the length of the gear shift rod on my 02 Formula (automatic transmission). Would there be any harm is cutting it with a grinder/dremel, say 1 inch shorter? I realize that inside the metal rod is a plastic rod that is engaged for shifting out of park. I presume that rod extends all the way down, but I thought I'd run it by those in the know before I start cutting. I could post a picture if it would help.
Old Apr 19, 2009 | 05:59 PM
1fastls1ss's Avatar
Just cut the outer metal stem carefully with a dremel then cut down the plastic inner part to the appropriate length (not to short or tall) to ensure it will engage. I did this to mine and cut it down about an inch, easy to do and looks better too.
Old Apr 19, 2009 | 09:19 PM
turbowhistle86's Avatar
not even remotely related to the topic, but I have always loved the look of your car, with the wheels and hockey stripe.
Old Apr 20, 2009 | 12:33 AM
VIP1's Avatar
Copy & Paste Moderator
Here are some threads on shortening the shifter:
https://ls1tech.com/forums/appearanc...installed.html
https://ls1tech.com/forums/appearanc...-write-up.html
https://ls1tech.com/forums/appearanc...-opinions.html
Old Apr 20, 2009 | 04:16 AM
Wisp's Avatar
You guys are awesome. Exactly what I was trying to find.
