fiting fuel rail covers
Old Apr 30, 2009 | 10:05 AM
95formulalt1's Avatar
Default fiting fuel rail covers
ok i got some nice fuel rail covers for my ls1. what/hows the best way to make them fit? im removing the egr and air pump. i tryed a search but no luck.
thanks
mike
Old Apr 30, 2009 | 10:37 AM
Gordo78's Avatar
You have to notch the front inside of the pass side to clear the TB cable bracket, and then i hacked off the outside corner of the pass as well. I also took off an inch or so off the rear or the drivers side, but i don't know if you have to do that or not.
Old Apr 30, 2009 | 12:22 PM
99zee's Avatar
Your picture is not showing up. If the covers are stock they will need to be cut to fit.
Old Apr 30, 2009 | 01:51 PM
FamousZ's Avatar
You can look at these to get the idea on cutting.. Some people said you don't even have to cut off that much..
