Badge removal
Old May 3, 2009 | 09:38 PM
jetfastformula's Avatar
Default Badge removal
hey guys i was thinking about painting the formula badges on doors but i don't know how they come off and i don't want to take a chance on screwing my paint up.
Old May 3, 2009 | 10:37 PM
99zee's Avatar
The Camaro ones are attached with emblem tape. I would think the Formula ones would be the same? I just took some fishing line and "sawed" up and down between the emblem and the car and they came right off. Use Goo-Gone, WD-40 etc to remove the leftover residue. Maybe someone with a Formula can verify that??
Old May 3, 2009 | 11:09 PM
Ten32's Avatar
I can verify that.
Old May 5, 2009 | 02:50 PM
Thanks I'll try that. Hopefully it will work out my car is blue and I am going to paint the badges silver. Thanks
Old May 5, 2009 | 02:58 PM
hlaalu's Avatar
use a blow dryer or leave your car in the sun for an hour, heat definitely helps. i used bug and tar remover on mine (says it was clear coat safe on the can)
Old May 5, 2009 | 03:28 PM
FormulaZR's Avatar
Before you remove it, though, you might want to take measurements so you can properly locate the emblem when you want to reinstall it.
Old May 5, 2009 | 04:49 PM
blown03mustang's Avatar
mine literally came off with no effort the other day. i had fishing line just in case but they came off easier than i thought. then use wd40 to get off the tape adhesive left behind
