Lightweight carpet
Old May 12, 2009 | 09:47 PM
ElkySS's Avatar
Default Lightweight carpet
how durable is it? how much does it increase nvh? what kind of weight savings am i looking at? where can i get it?
Old May 13, 2009 | 07:54 AM
Al 96 Ram Air T/A's Avatar
You are better off removing the padding on the back of the stock carpet.
I'm not sure how much weight you're going to save though. I took mine out last week to do a complete Raam Mat installation. The carpet doesn't seem to weigh all that much...maybe 15 pounds? Lightweight carpet or OEM carpet without the padding might save you half of that.
Is it worth it? Not too me...unless you are removing lot's of other stuff anyway.
Using the old "100 pounds of weight savings equates to about .1 in the 1/4 mile", I always thought the best savings came by way of using lighter wheels. A savings of 3 - 5 pounds per wheel will do more for the car than reducing the weight by 100 pounds. And, it'll increase the looks of the car without adversely affecting the safety or comfort.
Old May 13, 2009 | 08:26 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
check out the drag racing tech section. there is a thread somewhere in there about the lightweight carpet
Old May 13, 2009 | 08:10 PM
ElkySS's Avatar
is there a beg difference between stock carpet w/o jute backing and lightweight carpet?
quality wise and weight wise?
Old May 13, 2009 | 08:50 PM
luckyou03's Avatar
I tried it and wouldn't do it. The lightweight carpet feels cheap and wears easy. I ended up going back to stock. The weight is not worth it.
