How to Drill ABS Plastic
Old May 18, 2009 | 07:16 PM
qwikz28's Avatar
Default How to Drill ABS Plastic
Quick question. I need to drill into a blank piece of ABS plastic (think gauge pod material). What is the proper way to do so? Hole needs to be about a inch in diameter. I have a drill and dremel. Thanks
Old May 18, 2009 | 07:57 PM
Lotus289's Avatar
I'd spend the $10 and get a 1" hole-saw.
Old May 18, 2009 | 08:45 PM
99345hp's Avatar
yeah a hole saw would be the right tool.
Old May 18, 2009 | 09:28 PM
evilZO6's Avatar
Hole saw make sure it says plastic on the package.
Old May 18, 2009 | 10:06 PM
qwikz28's Avatar
gotcha. thanks guys
Old May 19, 2009 | 12:21 AM
evilZO6's Avatar
Originally Posted by qwikz28
gotcha. thanks guys
You know what else? I have some accessories for my dremel that i would recommend, i have the work station and i have the circle cutter/straight edge guide. If this was anything bigger than a 1" hole. i would have recomended this from the beginning but i highly recommend them! They are awesome! I also recommend the multipurpose cutter kit.
Circle cutter/strt guide
http://www.dremel.com/en-us/Attachme...spx?pid=678-01
http://www.dremel.com/en-us/Attachme...l.aspx?pid=565
Work Station
http://www.dremel.com/en-us/Attachme...spx?pid=220-01
The mini saw looks badass too, but i cant figure out what i would use it for! IM going to have to buy it just to f*** with it! All of these can be found on ebay for around $10-$20
mini saw
http://www.dremel.com/en-us/Attachme...l.aspx?pid=670
Old May 19, 2009 | 02:05 PM
qwikz28's Avatar
Work Station
mini saw
wow those are pretty cool. I'm going to look through my dremel catalog and see what they got at the hardware store before I purchase anything. I think I can get away with a smaller hole which is why i'd rather use the dremel. My drill is powerful as hell and I don't want to crack my plastic. Thanks for that, that's great info!
Old May 19, 2009 | 03:27 PM
evilZO6's Avatar
No problem, you can also spray the plastic with water out of like a spray bottle to keep it from getting hot and warping and i dont think it would crack
Old May 19, 2009 | 03:57 PM
hlaalu's Avatar
for plastic i use a high speed drill, drill a small pilot hole first, and then go to the size i need. apply a medium amount of pressure and you should be all set.
Old May 19, 2009 | 06:53 PM
qwikz28's Avatar
found a cutting attachment for my dremel at home depot. it was cheaper than anything else I found but it worked. just finished mounting up my new scangauge
