Clear corners leaking.....
Old May 17, 2002 | 03:33 PM
Damian's Avatar
LSX Mechanic
Default Clear corners leaking.....
I have had two different brands of clears in the car, and they both filled up with water. I even tried sealing up the top hole with silicon on the second pair, and still leaking. Any way to fix these POS's from leaking??
Josh
Old May 17, 2002 | 03:44 PM
Z-Rated's Avatar
Default Re: Clear corners leaking.....
I had this same problem. To fix it for me was to make sure that the light is tight as it can get. It clicks in place. I know it sounds obviuos, but i had a quarter of an inch of water in mine <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> There is a little plastic piece that prevents the light to fit properly. Turn it really hard and make sure its tight. Hope it helped
Drew
Old May 17, 2002 | 05:20 PM
adm408's Avatar
i had the same problem with my pacific import export clears. i fixed it by drilling 4 or 5 small holes in the bracket that holds the clears. if you pour a little water onto the bracket you can see where the water forms a small puddle and thats where you want to drill. it worked like a charm for me. also, try not to spray high pressured h2o directly at the clears (i learned this the hard way).
-anthony
--hope that helped at all
