Replacing Cowl Grill
Old Jun 1, 2009 | 07:53 PM
dd11856's Avatar
Default Replacing Cowl Grill
The right part of my cowl grill is cracked. I have a replacement, however, I need to figure out how to remove the original first. Also, how can I transfer the weather stripping at the bottom from the original to the replacement? Can I reuse the original plastic pins that hold it in place, or will I need to buy these and new weather stripping also?
Old Jun 1, 2009 | 08:03 PM
my bandit's Avatar
you can reuse the push pins if you dont break them... and you can reuse the weatherstripping also. just pull out the middle pin with a screwdriver and plyers
