pillar gauges
This will be very helpful.
http://www.egauges.com/AM_Instr.asp
For power, run it off your radio. Same thing with the ground.
Black 10-pin connector
5 - BLACK - ground
9 - YELLOW - ignition controlled power
For your A/F (assuming it's a narrowband), you'll need to read off either your front driver side, or front passanger side O2 sensor. You'll have to splice into one of two wires which run to your PCM. It will vary depending on if you have a 1998 vs. 1999+ car.
If it's a 1998 car, they are located in the blue PCM:
46
PPL
HO2S Signal High Bank 2 Sensor 1
47
PPL/WHT
HO2S Signal High Bank 1 Sensor 1
I'm pretty sure that is accurate.
