Stay away from this crap!!!! DO NOT USE!!
Old Jun 6, 2009 | 06:47 PM
BrianB's Avatar
Default Stay away from this crap!!!! DO NOT USE!!
Wow used this crap on my powdercoated rims last night and this is what I woke up to this morning. The only reason I got this stuff was because it came with the wheel and tire cleaner for free. Needless to say it sucks and took me forever to get it cleaned off.
Old Jun 6, 2009 | 06:50 PM
Mean Green z28's Avatar
ouch .. that's crazy
Old Jun 6, 2009 | 08:09 PM
Yelo's Avatar
it's acid...you have to rinse it and then use a degreaser (a base) to neutralize it or you'll get that on any kind of wheel. you're lucky you were able to get it off at all.....
hlaalu's Avatar
do they tell you leave it on or something? looks horrible!
Old Jun 6, 2009 | 08:13 PM
ZaneO's Avatar
What are the instructions for use?
Old Jun 6, 2009 | 08:14 PM
Blacked_Out_SS's Avatar
my old wheels on my 87 T/A did the same thing when i tried to use wheel cleaner.... i finally stopped using wheel cleaner and just used soap and water then polished them..... they were centerline telstars with a polished aluminum finish....... how did you get that off the wheel?
Old Jun 6, 2009 | 08:16 PM
Gordo78's Avatar
Looks like a wheel wax. We use some at work and you're suppose to mist it on, and wipe it off according to our stuff. I know some of that stuff says to leave it on, but you end up with that crap.
Old Jun 6, 2009 | 08:55 PM
Quik Sand's Avatar
[QUOTE=BrianB;11714841]Wow used this crap on my powdercoated rims last night and this is what I woke up to this morning. The only reason I got this stuff was because it came with the wheel and tire cleaner for free. Needless to say it sucks and took me forever to get it cleaned off.
[QUOTE]damn that sux
Old Jun 6, 2009 | 10:02 PM
Norway's Avatar
all eagle 1 wheel cleaners are crap Ive tried 3 of them, 1 i bought and the other times a friend would have it at a detail session, i used it once and threw away the bottle, even when i rinsed each wheel as it said in the instructions that nasty crap would be all over. time it took to get the crap off after it dried...... 20 min. per wheel. i've found that soap and water are your best friends.
Old Jun 6, 2009 | 10:55 PM
BrianB's Avatar
This isn't a cleaner, it's supposed to go on after you clean and dry the wheels. The instructions say to let it dry and that it will dry clear. It is supposed to put a "protective barrier" on the wheel so that brake dust and other elements can't penetrate the wheels finish and damage it. Well, it didn't dry clear that's for damn sure! I love their A2Z wheel and tire cleaner and since this came free with the purchase I thought I would give it a try since my car is a daily driver and I have damn Hawks pads up front that dust like crazy.
Old Jun 6, 2009 | 11:03 PM
BrianB's Avatar
From Eagle One's web site
Keep Clean Wheel™ – 18 oz.
Repels brake dust & road grime for up to 2 weeks
Apply after cleaning wheel (this is not a wheel cleaner)
Protects wheels from corrosive brake dust
Makes it easier to clean wheels every time you wash
Usage directions:
Make sure wheel is clean and completely dry of water before application
Shake well before using
Hold approximately 4 to 6 inches away from wheel surface.
Spray wheel surface with a THIN, EVEN coating of product. Be sure to cover recessed areas, so the entire surface is covered.
Do not touch the wheel once you have applied the product as this will remove the coating from the surface of the wheel.
IMPORTANT NOTE:
Surface should appear wet. During the drying process, the surface of the wheel will appear hazy for approximately 5- 15 minutes. Wait 10-15 minutes before using your vehicle. Coating will be invisible once it has dried
Old Jun 6, 2009 | 11:25 PM
99Bluz28's Avatar
Damn, that totally sucks ***!
IMO, contact Eagle One as many times as it takes to get a response from them.
Old Jun 6, 2009 | 11:54 PM
99Ws6TransAm's Avatar
it looks like you just used to much. Still sux..and id prob throw it away myself after waking up to that lol.
Old Jun 7, 2009 | 02:24 AM
sway99bird's Avatar
That ain't worth a ****
Old Jun 7, 2009 | 02:30 AM
98 WS6's Avatar
IMO, wheel cleaners are just crap period. Soap and water has never failed me, and if need-be, a nice polish afterward.
Old Jun 7, 2009 | 11:17 AM
hitmanws6's Avatar
black magic wheel cleaner works very well
Old Jun 7, 2009 | 11:39 AM
redbadss's Avatar
i just spray some meguirs ultimate detailer after i wash my car and wheels, works amazing and the wheels stay clean for a couple weeks
