Getting Rid Of Swirls........
But what is the best stuff that i can get from like AutoZone that will get rid of my swirls? I want my paint to be brillaint, glossy, deep and wet looking... My paint jsut needs some help
I think my absorber is what gave me my swirls. So i have since bought a leaf blower... I will then purchase a waffle weave from Steve at Tropi-Care... Speaking of Steve.. He will not detail my car
So please help me. I have used the Meguiars 3 step process, and the NXT line too.. So what else should i do????
Get Meguiars Mirror Glaze line.
Willing to order online??
Prima Swirl followed with Prima Amigo and a wax works really well...even by hand.
Although the Swirl will take a LONG time to work in by hand. Hell, takes a long time with a PC or Flex.
for just swirls, tropicare SC (swirl cutter) works well. if they still wont come out, then you need to step up in compounding.
i dont think the absorber gave you the swirls. it was probably the orbital buffer, or whatever you may have used by hand. i bought the waffle towel from TC, and i really dont like it. it doesnt absorb worth a damn once it gets wet. all it does is smear the water around, creating streaks like you wouldnt believe. you ALWAYS have to follow up with a wax or detail spray. i bought the absorber because i didnt want to HAVE to detail/wax after every single wash. sometimes all i wanted to do was wash her after a track day, and back in the garage, without spending another hour plus detailing.
This will serve you well and give you results that cannot be accomplished by hand for about $80-$85 in total.
3M's Perfect-It 3000 Ultrafina SE is an awesome swirl remover!
In the last 2 days I have shown 3 women how to use the PC equipped with an orange pad/Menzerna SIP combo. Afte a short learning curve with the machine use, they successfully were removing fine lines/swirl scratches from both a BMW and Maserati.
As for your absorber, you need to check all items that come into contact with the paint. If it leaves fine lines on the back of a CD, it will also scratch the clearcoat.
I have been getting great results with microfiber waffle weave towels for years. For best results with their use, I get them barely damp to start. Drawing the towel lightly over the surface to absorb the water, I'll wring it out as it get saturated. Using detail spray to remove any light water spotting after drying is fast, easy and removes any static charge from the surface.
Feel free to contact me with any questions.
Check out autogeek. The orange pad is by Lake Country. Try it on a Porter Cable 7424 with Menzerna SIP. You will have great results.
try tropicares website, and get one of their starter kits. has about everything you need to start buffing.
http://www.tropi-care.com/Orange_Lig...d_p/tcp-02.htm
We also have LC 5.5" flat foam pads in orange,white, and yellow at $8.49 each w/free shipping.
4" Lake Country pads@$4.09 each shipped.
