GTO shift knob installed pics
Old Jul 2, 2009 | 09:54 AM
97ramsst's Avatar
Originally Posted by TPI TERROR
noh it wont..it doesnt have thread inside. i worked on a gto shifter assembly..and its a press on (push on)wierd style
Is it close enough to the right size you could epoxy it onto a stock handle? I found a new one for $187 but dont want to spend that and then not be able to use it on my chromed factory Hurst stick!
Old Jul 2, 2009 | 10:23 AM
SOMSS1LE's Avatar
Originally Posted by mrsinister2424
Yeah! Push button ignition. How does that work anyway? You have to have your key turned to the on position and then press it? Are you able to still start the car with the keys?
I have one in my car, you still need the key to start it. Half way, then hit the button.. I can also start the car with the key without hitting the button. It's more of that cool factor but besides that it's pointless.
Old Jul 2, 2009 | 12:28 PM
therobman's Avatar
thanks guys yea the push button works exactly like the guy listed above and the stick was close but too big to fit into the **** so i had to grind it a little but yea bacially jb weld on the stick and in the **** slap it on and let it dry and bam the hardest part was painting the numbers
Old Jul 2, 2009 | 01:27 PM
therobman's Avatar
heres a few more pics
Old Jul 2, 2009 | 01:30 PM
Brickyard's Avatar
Looks sharp man.
Old Jul 2, 2009 | 01:31 PM
02gtp4now's Avatar
wow, that looks really good, and the red r really sets it off.
99Ls1fever's Avatar
Looks really good!!! Do you have a link to more pics of your car and interior?
Old Jul 2, 2009 | 03:05 PM
RickyMartinZ28's Avatar
You have tabs to hold your mats in place? Is that factory?
Old Jul 2, 2009 | 04:10 PM
therobman's Avatar
thanks guys um yea
and no those tabs arent factory
Old Mar 26, 2010 | 12:27 AM
02cetransam's Avatar
this set up looks amazing!!
Old Mar 26, 2010 | 09:55 AM
black_sheep454's Avatar
That looks great, stitching matches shift boot great
Old Mar 26, 2010 | 02:07 PM
  #32
z_speedfreak's Avatar
looks good! def the only 1 I've seen in an f-bod
Originally Posted by therobman
now whats that switch for?
Old Mar 26, 2010 | 03:27 PM
  #33
therobman's Avatar
thanks guys its for an electric cut out
Old Mar 26, 2010 | 03:29 PM
  #34
Trans Am Jam's Avatar
looks dope. good job on the modern touch
Old Mar 26, 2010 | 09:02 PM
  #35
TransAm578's Avatar
That looks great! Very classy.
Old Mar 27, 2010 | 11:57 AM
  #36
TempleU_WS6's Avatar
Looks great. My only input would be to do something about the stock shift pattern. Have a something made to cover it up or something.
I think it looks tacky seeing the 6spd pattern on the **** and in front of it.
