couple of mods done in my interior..
I'm not even going to lie about these vent rings, they were a PITA. I removed the vents, knotched them, glued them and reinstalled them.
That shift **** looks worlds better than what came in the car stock. I also don't think the steering wheel looks bad at all. I can see what you mean by it looking out of place, but I would say that is only because the interior needs more silver accents to help complement it.
- remove the stock ****
- remove the white plastic tube
- used a dremel to cut the black tube to alow the new shift **** to have room to go down.
- re-painted the black tube
- cut a 1/4 rod the correct length and drilled out the bottom so it would sit on the shift mechanism correctly and wouldn't slip off (a 1/4 chrome ratchet extension works great for this. it is what i used.)
- slide the new **** on the 1/4 rod
soo.... technically if i wanted to, I could use a 10mm socket as my shift ****.
