Whistler Mod Oven temp???
Old Jul 5, 2009 | 03:49 PM
Taken4granted's Avatar
Default Whistler Mod Oven temp???
so im about to start this project, and I read the stickies and im a little confused on what tempature to put it on? one says 200 degrees for 20 mins that other says 300 for 10 mins, which is the best one where I wont melt my headlights?????
Old Jul 5, 2009 | 05:03 PM
crispytoast's Avatar
i did mine 200 for somewhere between 20 and 30 min. If i remember correctly 20 min just isn't long enough so i popped it back in when the lens wasn't coming off easy.
Old Jul 5, 2009 | 05:05 PM
RA032926's Avatar
i was always weary about putting lights in an oven... i personally haven't worked on any camaro headlights but i don't think they could be any different... i have always used a hair dryer or if you have a heatgun that would work but be really careful with it
Old Jul 6, 2009 | 03:54 PM
I tried 20 didnt work either so, im gonna try 30. if feels brittle. did you work on one side until it came off or worked all the way around???
Old Jul 6, 2009 | 03:55 PM
-98-Z28-Darkness-'s Avatar
i was scared too but nothing happens just put them at the lowest temp possible and check every 5-10 min till they get easy to open with 2 screwdrivers. you can try the heat gun but i think it would be hard to get even heat all the way around and might even crack the lens if one part is still stuck on well.
Old Jul 6, 2009 | 04:19 PM
I had it at 200 and its coming loose but still holding, so I turned it up to 250. im also using a hair dryer to keep it hot enough, its 80+ outside and hot as **** in the kitchen
Old Jul 6, 2009 | 07:54 PM
what is the best way to get rid of the sealant around the headlights?????
