Need a part Number
Old Jul 9, 2009 | 11:13 AM
Black_Z28's Avatar
Default Need a part Number
Does anyone know the part number for the triangular shaped piece in the upper right corner of the driver side door? It's also a common place that guys place aftermarket tweeters. Mine some how broke, and I would like to replace it.
Thank you.
Old Jul 9, 2009 | 11:46 AM
RAMPANT's Avatar
What broke on it?
If it is where the screw goes through and you kept the parts. You can use a soldering iron to weld the plastic back together. I have some old parts kicking around and trimed some of the plastic off and used it as filler material and I bet it is now stronger than stock!
Old Jul 9, 2009 | 12:43 PM
Black_Z28's Avatar
Originally Posted by RAMPANT
What broke on it?
Yep, the hole where the screw goes is the part that broke. I guess I never thought about melting it together. Good idea.
I'll give that a whirl first.
