2000 trans am door emblem
Old Jul 10, 2009 | 01:10 PM
sally's Avatar
Default 2000 trans am door emblem
What is the easiest way to remove these off the door to paint? Thanks
Old Jul 10, 2009 | 02:44 PM
taws6m6's Avatar
I heated them up with a blowdryer, and sprayed some wd-40 while I was pulling them off to cut thru the glue. I didn't have a heat gun, I would be careful if you used one though. wasn't too bad. I pulled them cause I don't like emblems.
Old Jul 10, 2009 | 06:57 PM
RA032926's Avatar
i used a long piece of fishing string, wrapped it around both of my hands and used a sawing motin behind the emblems to break the glue loose... then i used my fingers to remove as much of the glue as possible then used wd40 and elbow grease to get the rest off... when i was done i waxed it and you can't tell anything was ever there... i chose to leave mine off
Old Jul 12, 2009 | 08:35 PM
theskitztikwon's Avatar
or guitar string
Old Jul 12, 2009 | 09:10 PM
pheer's Avatar
Originally Posted by theskitztikwon
or guitar string
could possibly scratch paint?
Old Jul 12, 2009 | 09:42 PM
RA032926's Avatar
yeah i think the guitar string could definitely scratch the paint... i tried to just peel them off but they were glued on pretty good and felt like they would snap so i just used the fishing string and elbow grease... worked just fine for me
