caliper painting ????
Decals go on after the paint is fully cured.
Depending on what color you want Plasticat makes excellent paint specifically for calipers, but is only limited to red, yellow, blue and black. Very resistant to brake dust. You can get it a Pep Boys.
and thanks again i appreciate it!!!!!
I used duplicolor high heat paint and clear coat. Put 3 coats of paint on, and while the last coast was slightly tacky I installed the sticker. Then put 3 coats of clear to help hold the decal in place and increase the shine.
If I had my camera I'd post some pictures, but I must say, they couldnt have turned out any better. They look awsome!
Suggestion: Take the extra time and remove the caliper totaly. Some people try to mask everything on vehicle and hang it in the wheel well with a coat hanger. Saveing them the hassle of bleeding the brake lines. (Its not worth it) Its a lot easier to work with when its off the car and in your hands. Besides, it makes painting easier.
TIP: The calipers fit perfectly atop a can of old spray paint. Great for elevating the caliper while painting, and it allows yout to hold it up and spray the underneath areas without getting finger prints on the already painted areas.
Good luck.
