Clear corner installation
If you look at it from directly under thecar you can see that the foam kinda makes an "L" shape and is almost butted up against the light housing. I just took an exacto knife and cut the "L"" extension by the light off and pried it out with a screw driver.
The lights sid right out this way.
The whole install took about 15 minutes
<strong>Hey dj i did remove the headlights, but the part that i am having trouble with is pulling the lens out..it seems to be to big to pull out..did your lens just pop right out? thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It is a tight fit and you need to move it around to remove it. I had the same problen you had, then it just came out easily. Also did you remove all the screws off the lens when you tried to take them out ?
before i traded it on my 02Z
d
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>Thanks everybody for the great advice!! It's sort of comforting to hear that i am not the only one that ran into this problem. As always any info is always cool to hear.
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Did you get them on ?
Black 99 SS,MTI lid,K&N,Hotchkis stress bar,Bilstein shocks, SLP short shifter,Skip shift eliminator,Auburn rear,MSD 8.5mm wires,cutout,clear lenses, clear side markers, billet grille
<small>[ June 18, 2002, 08:25 AM: Message edited by: Xsta Z 28 ]</small>
Al
