Gauge Wiring
Old Aug 6, 2009 | 09:31 PM
magnus66's Avatar
Default Gauge Wiring
I am installing a temperature and a air fuel guage on my 2002 trans am and I was wondering what power wire I should hook them up to underneath the dash that only has power when the key is on?
Old Aug 6, 2009 | 09:44 PM
hlaalu's Avatar
i wired mine to the cig lighter i think... but i guess you could tap into the power going to your radio
Old Aug 10, 2009 | 12:37 AM
magnus66's Avatar
I wired it into the radio wire and now my odometer and trip gauge is a lot dimmer and is really hard to see and also it made all of my gauges speedometer and everything quit working so i put a bigger fuse in it but the odometer is still very dim
Old Aug 11, 2009 | 01:11 AM
DopeFedZ's Avatar
Pull the panel right under the steering wheel. Pink wires are switched 12 volts.
Old Aug 11, 2009 | 12:15 PM
Bad30th's Avatar
I connected the (+) for mine to the ignition switched power in the driver-side panel fusebox, and tapped into the ILLUM and (-) from the radio harness.
Rob (Bad30th)
