pulling off badges?
Old Aug 19, 2009 | 06:37 PM
greezy's Avatar
Default pulling off badges?
just curious if anyone has done it yet. im talking about the transam it says on the door. i want to paint either the sides to give it depth or all of it. is there a better way than a flathead and some replacements on my ebay watch list?
Old Aug 19, 2009 | 06:48 PM
latindragons's Avatar
There are a TON of threads on removing the badges. A safe way would be to find a lose part and slide in fishing wire to remove the glue as you pull gently. Then use goo gone to get rid of the extra adhesive on the car. The hardest part would be actually lining up the "Trans Am" and the spacing between letters when you go put it back on using 3M tape (I think that's the method preferred).
That would be an interesting idea for painting them, though.
Old Aug 19, 2009 | 06:54 PM
greezy's Avatar
Originally Posted by latindragons
slide in fishing wire to remove the glue as you pull gently..
thats a good idea. ima try that.
ya i thought about that also. my kids got an *** load of playdough. wonder if i made some sort of jig or mould of it if i can use it
