AC Knobs
Old Sep 30, 2015 | 03:08 AM
  #121
BirdsSince16's Avatar
This mod just exploded in a matter of a couple weeks from only one or two guys. This community is great.
Old Sep 30, 2015 | 06:17 AM
  #122
The Alchemist's Avatar
UNDER PRESSURE MOD
Mine are all metal as well.
Old Sep 30, 2015 | 01:32 PM
  #123
Double-aught_Z/28's Avatar
Do you have the specific model or part number of the ones you got?
Old Oct 2, 2015 | 12:57 PM
  #124
1sicLS1's Avatar
Yes Alchemist which link did you specifically use?
Old Oct 10, 2015 | 02:46 PM
  #125
rimfire27's Avatar
One down, 2 to go.
those look awesome are those the mazda 3s?
Old Oct 16, 2015 | 12:40 PM
  #126
Viper's Avatar
Alchemist
Which ones did you buy?
Viper
Old Oct 16, 2015 | 07:59 PM
  #127
rimfire27's Avatar
Alchemist is trying to keep it a secret from reading over and over on this thread i think they are mazda 3s, hate to buy the wrong ones though seems like they all take a month to deliver , c'mon alchemist we love you now SHARE YOUR SECRETS lmao
Old Oct 17, 2015 | 05:53 AM
  #128
UNDER PRESSURE MOD
Sorry, I am not keeping it a secret, I just forget each time I read this to go search where I bought mine from.
I got them from ebay, here's the link.
http://www.ebay.com/itm/201120134129?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I need to use something different than the gorilla glue. It doesn't get hard enough, so now my **** is 'spongy' because the metal 'D' ring is flexing in the gorilla glue. I'm going to have to figure out something else and redo it.
The search continues.
Old Oct 19, 2015 | 11:34 AM
  #129
stealth355tpi's Avatar
Some JB weld maybe?
Old Oct 19, 2015 | 12:20 PM
  #130
UNDER PRESSURE MOD
Originally Posted by stealth355tpi
Some JB weld maybe?
That may work.
I just noticed, this is my 10,000th post. I win a bag of internets....
Old Oct 19, 2015 | 02:54 PM
  #131
Unertl42's Avatar
I'll email Al Gore, and see if he has any internets left
Old Oct 20, 2015 | 11:20 PM
  #132
Killer_Z's Avatar
n e one thought of maybe bondo or jbweld? i'm sure it will take some work getting it on there cleanly but it would hold better then gorilla glue wont flex.
I c jbweld was just mentioned. haha.
Old Oct 21, 2015 | 08:06 AM
  #133
LT4vert's Avatar
I think clear epoxy or plastic weld epoxy would be the best thing to use here. The plastic used in these buttons is not a low energy plastic so epoxy well bond very well.
Old Oct 21, 2015 | 09:45 AM
  #134
86_irocz-28's Avatar
I used quick steel stuck the d insert in then used a dremel to remove any excess material that was inside the sleeve 0 flex
Old Oct 21, 2015 | 09:58 AM
  #135
blackbyrd's Avatar
3 Pcs Air Condition **** Car A C Heater Control Switch for 2005 2012 Ford Focus | eBay
those look very nice
how big is the gap? I wonder if something could be 3d printed to close the gap a bit better?
Old Oct 21, 2015 | 03:57 PM
  #136
The gap isn't the issue really its the fact that there 180° off
Old Oct 22, 2015 | 08:33 AM
  #137
rimfire27's Avatar
anyone look into plastic welding? sounds silly I know, but there are videos out there and all you need is a soldering iron
I ordered mine and they should be in by thanksgiving (damn it china), but thats what Im going to attempt...
Edit: Plastic welding would be good but is a **** ton of work and getting everything to line up would be hard.So, Im going the tang route.The image should be self explanatory ,and Ill update tomorrow on the results.
UPDATE: **** number 1 worked great, just make sure the metal "D" stays perfectly center for about 24 hours, mine was a little off and is a little noticeable and it has about 1/16 play on all settings,but looks great regardless.I think that was the "spongy" thing brought up earlier, but clamp the D metal down using pliers until there is no gap in the center to avoid that.I'm doing the other two now and just used a mechanic pick to remove the metal this time, the only thing bothering me is that these dont have the red plastic in them so they have a dim stock yellow light color to them. So, I ordered some 6k 94 wedge 360 LEDs and a made some resisted red LEDs to go in the ***** themselves....Which forced me to take out the entire HVAC control and test them on my converter, update when the wedges come in.
Any one else still working on this?
Old Nov 2, 2015 | 03:48 PM
  #138
rimfire27's Avatar
awesome
Old Nov 2, 2015 | 04:00 PM
  #139
Looking good. Instead of wiring in red leds, do you think it'd work to dye clear plastic red? Just giving it a thought
Old Nov 2, 2015 | 04:56 PM
  #140
rimfire27's Avatar
Thats a good idea but i Ithink itll mess with the blue coloring on the control overlay
EDIT: yea the actual clear plastic inside the ***** would be a great idea Id have to do some research on that, I thought you were talking about dying the clear plastic behind the overlay itself
By Brett Foote | 2026-06-04 05:00:17
